[Nakamichi]NAKAMICHI NBF25.0A 10" FULL ALUMINUM ACTIVE SUBWOOFER SPECIFICATIONS N-Power: 150W Peak Power: 1000W Distortion (THD): <...
214197007_3125360164366744_2332054259362901723_n.jpg?_nc_cat=101&ccb=1-3&_nc_sid=8024bb&_nc_ohc=zJhGx7jP9AAAX9AgtaD&_nc_ht=scontent.fgig4-1.fna&oh=7a95b748328cd3ef4290768a34f11802&oe=611F5676
NAKAMICHI NBF25.0A 10" FULL ALUMINUM ACTIVE SUBWOOFER SPECIFICATIONS N-Power: 150W Peak Power: 1000W Distortion (THD): <0.5% Signal To Noise Ratio: >90dB Frequency Response: 20Hz-180Hz Input Sensitivity, High Level: 1.0V Input Sensitivity, Low Level: 300mV Low Pass Filter: 50Hz-180Hz Bass Boost: 0 to -12dB Fuse Rating: 25A Subwoofer: 10 inch, 4 ohm Unit Dimension: 300x225x72mm
