[Nakamichi]NAKAMICHI NBF20.0A 8" FULL ALUMINUM ACTIVE SUBWOOFER SPECIFICATIONS N-Power: 100W Peak Power: 650W Distortion (THD): <0....
217220778_3125357271033700_4666542102434006480_n.jpg?_nc_cat=108&ccb=1-3&_nc_sid=8024bb&_nc_ohc=rJ8z27llQ2gAX_VCaGi&_nc_ht=scontent.fbel16-1.fna&oh=9b35d709784e36cb2b200aa655f1e962&oe=60FE9350
NAKAMICHI NBF20.0A 8" FULL ALUMINUM ACTIVE SUBWOOFER SPECIFICATIONS N-Power: 100W Peak Power: 650W Distortion (THD): <0.5% Signal To Noise Ratio: >90dB Frequency Response: 20Hz-180Hz Input Sensitivity, High Level: 1.0V Input Sensitivity, Low Level: 300mV Low Pass Filter: 50Hz-180Hz Bass Boost: 0 to -12dB Fuse Rating: 20A Subwoofer: 8 inch, 4 ohm Unit Dimension: 290x210x69mm
