[Nakamichi]NAKAMICHI NDSR350A 6 IN 12 OUT 31 EQ DSP AMPLIFIER PRODUCT DATA Dynamic Range(RCA Input) ≥100dB S/N(RCA Input) ≥90dB THD...
211942311_3125339001035527_7922621285158126770_n.jpg?_nc_cat=111&ccb=1-3&_nc_sid=8024bb&_nc_ohc=J6iiYjTQa0MAX8Anj0D&_nc_ht=scontent.fpnq5-1.fna&oh=863d3160e257b63d6cf38daa4d1a4d48&oe=60F88F34
NAKAMICHI NDSR350A 6 IN 12 OUT 31 EQ DSP AMPLIFIER PRODUCT DATA Dynamic Range(RCA Input) ≥100dB S/N(RCA Input) ≥90dB THD ≤0.05% Frequency Response 20Hz~20KHz Input Impedance High Level Input:51Ω Low level Output Impedeance 51Ω Signal Input Range RCA Input:7.5Vpp;High Level Input:26Vpp Signal Output Range RCA :7.5Vpp;Amplifier Maximum Power:2CH×80W(Bridged:1×160W)+4CH×40W+4CH×25W Power DC 9V-15V REM Input High Level Input Signal:H1+/H1-or ACC control cable REM Output +12V Start up Voltage Output Standby Power ≤0.1W Gross Weight Approx. 2.24kg Product Dimension(L×H×W) 217×48×186mm TECHNICAL SHEET Input Type 6 Channel high level,2 Channel low level,Built-in and External digital Buletooth ,Optical/Coaxial Output Type 12 Channels low level,2CH×80W(Bridged:1×160W)+4CH×40W+4CH×25W power Output Gain Gain range:Mute,-59dB~0.0dB Output Signal EQ 31 Band Equalizer Engine: 1.Frequency Range:20Hz~20KHz,1Hz Accuracy 2.Q value(Slope):0.404~28.852 3.Gain:-12.0dB~+12.0dB,0.1dB Accuracy Output Signal Crossover Each output is equipped with multi-order high and low pass independent filters. 1.Professional filtering types:Butter-W, Bessel,Link-Rill 2.Filtering frequency division point: 20Hz~20kHz, Resolution 1Hz 3.Filter Slope(slope) setting:6dB/Oct ~ 48dB/Oct and OFF Output Phase and Time Alignment Each output channel can be adjusted for phase and delay,parameter range Phase:in-plase or reverse-phase(0°/180°); Delay: 0.000 to 20.000 mill, 0 to 692 cm,0 to 273 inch. Presets 6 presets into the device.
