LUC_SCS
[Vendido] - Amplificador Diamond Audio D600.4
[VENDIDO ao amigo kowalsetskyj]
Amplificador 4 canais Diamond Audio D600.4
Possui Marcas de uso
Todos os canais funcionando perfeitamente
Motivo da venda: desmontei o som do carro
90 watts RMS x 4 at 4 ohms (150 watts RMS x 4 at 2 ohms)
300 watts RMS x 2 bridged output at 4 ohms (4-ohm stable in bridged mode)
separate variable high- and low-pass filters (50-250 Hz, 12 dB/octave) on front and rear channels
separate variable bass boosts (0-12 dB at 50 Hz) on front and rear channels
focused mass heatsink improves cooling
Class AB amp technology
frequency response: 20-20. 000 Hz
fuse rating: 40A x 2
20210712123740amp_diamond01.jpeg20210712123740amp_diamond02.jpeg20210712123740amp_diamond03.jpeg
Editado por LUC_SCS
vendido
Visitante
