robson.bruno
[VENDiDO] Amplificador Modulo Mosconi Gladen Ital. One 120.4 + Brindes
NÃO ACEITO TROCAS
Condição: Impecável (sem falhas, avarias ou histórico de reparos)
Tempo de Uso: 2 anos
Motivo Venda: Mudança para exterior
Amplificador Italiano Mosconi Gladen One 120.4
+ Brindes:
- 2 RCA's Nakamichi Stonehenge 0.5 Mt
- 2 RCA's Nakamichi Stonehenge 0.7 Mt
- 2 RCA's Nakamichi Stonehenge 2.5 Mts
Technical Features
Power Rating: 120 Watt per channel @ 4 Ohm < 1% THD+N
Sn Ratio: > 81 dBA (ref: 1 Watt into 4 Ohm)
HANDY POWERFUL RANGE
The smallest line with fresh and dynamic young sound recommended also for OEM applications. Absolutely great features on board like Front Stage Adjuster FSA and High Level Input with auto-switch on.
Besides, thermo controlled fans and Plug & Play wiring harness (optional).
Low Level (LL) and High Level (HL) input
Target powers:
170 Watt per channel @ 2 Ohm
340 Watt BTL mode @ 4 Ohm
Input sensitivity: (Power rating ref)
0.35 V ÷ 16 V
Xover functions: (HIGH Pass or LOW Pass)
(45 ÷ 225 Hz – 12 dB/oct)
Special Features:
Remote Volume Control (optional)
Phase Shift 0° ÷ 180° (Rear)
High Low Adapter
Size:
310x200x50 mm
Weight:
2,7 Kg
https://produto.mercadolivre.com.br/MLB-1650276843-amplificador-modulo-mosconi-gladen-ital-one-1204-brindes-_JM#position=2&type=item&tracking_id=1c11a07c-64f5-44cc-84f0-875d0cf2cd45
Editado por robson.bruno
Visitante
