igortbq
[VENDO] DB Drive Okur apa 80.4
Amplificador db drive okur apa 80.4
Completo (caixa e manual);
Linha marinizada.
Valor: 350,00 - frete free
Sem trocas
Especificações (site oficial)
  • 4 Channel Amplifier Class AB
  • Output Power rated @ 14.4 volts
• 4 x 80 Watts @ 4 Ohm
• 2 x 200 Watts @ 4 Ohm (Bridged)
• 4 x 140 Watts @ 2 Ohm
    • Drivesink Heat Management System
    • Buffered Pre-amp input Circuitry
    • Continuously Variable 12dB Low Pass X-over
    • Variable 12dB Bass boost @ 45Hz
    • 4 Channel 2 Ohm Stereo Capability
    • Direct Connect Speaker Power Wire Terminals
    • Full Range RCA Line Outputs
    • RCA Configuration
    • Variable Input Level Control
    • DC-DC PWM Power Supply
    • DC Short Circuit Protection
    • Elastoquatic Coating Solution on PCB Component
  • Ideal for Marine and Off Road Vehicle
2019061010535962408756_2513311805577770_
UP! Pessoal está perdendo uma ótima oportunidade de um amp com bom cxb e vida útil.
