Maarcoss123
[VENDO]Par de fullrange Audible Physics Ram3 3"
Par de fullrange Audible Physics, modelo RAM3 - 3" polegadas
Falante de alta definição.
Estética 9,9/10
Funcionalidade 10/10
Overall Diameter: 88 mm / 3.46”
Cutout diameter: 74 mm / 2.91”
Mounting Depth: 1.7”
Net Weight: 2.75 lbs
Nominal Power Handling: 15 watts
Nominal Impedance: 4 ohm
Sensitivity: 83.6 db / w / m
Frequency Response: 93 – 20,000 hz
Resonant Frequency: 93 hz
 DC resistance: 3.8 ohm
Magnet system type: Ferrite
Magnet Gap Height: 3 mm /
B flux density: 1.1 T
BL: 2.084 TM
Max linear excursion:
Cms: 1.090 mm / N
Sd: 28.274 cm sq
Vas: 1.237 L
Mmd: 2.679 g
Qms: 2.764
Qes: 0.677
Qts: .543
R$ 1500,00
https://produto.mercadolivre.com.br/MLB-1186014802-fullrange-audible-physics-ram-3-3-_JM?quantity=1&variation=33481487177
Tenho outros itens a venda, estou aceitando trocas por CPU.
