AndCamp®
Subwoofer 12" Rockford Fosgate Prime R1 250 Watts RMS 250 Watts Pi
Subwoofer 12" Rockford Fosgate Prime R1 250 Watts RMS 250 Watts Pico bobina dupla 2-Ohms (sem uso na caixa)
Parcelo pelo Mercado Pago (taxas e juros por conta do comprador)
R$390,00
Especificações
Voice Coil Diameter
2" (50 mm)
Speaker Connector
Dual 12 AWG compression
Shipping Weight
12.013 Lbs. (5.44 kg.)
Fs (Hz)
29.7
Qts
0.66
Qes
0.71
Qms
9.00
Cutout Diameter
11.25 in. (285 mm)
Woofer Displacement
0.039 cu. ft. (1.1 Liters)
Sd (cm2)
534.8
Size
12"
Nominal Impedance
Dual 2-Ohm
Magnet Weight (oz)
51 oz. (1.45 kg.)
Mounting Depth
3.602 in. (91 mm)
SPL (dB @ 1w/1m)
85
Re (Ohms)
3.80
Le (mH)
4.2
CEA-2031 Compliant
Vas (Liters)
65.4
Xmax (mm)
10
Subwoofer Type
Shallow
Voice Coil Type
Dual Voice Coil
Sealed Box Volume (Vb)
25.4 Litros
Vented Box Volume (Vb)
50.6 litros
