michel.balazs
[VENDO] Head Unit / Receiver Kenwood Excelon Kdc-x995 Bluetooth Usb
Cd Player Receiver Kenwood eXcelon Kdc-x995
R$ 649,99
Em perfeito estado de funcionamento
eXcelente aparelho para que quer montar um som de qualidade.
Completo e com caixa!!!
OBS: A cinta (moldura) de fixação do aparelho no painel do carro não está travando o aparelho corretamente pois não é uma cinta Kenwood. Não possuo a cinta Original!
  • M/FM CD receiver (with 10-amp fuse inserted into the chassis)
  • Sleeve (attached)
  • Face (attached)
  • Trim ring (attached)
  • Wiring harness
  • RC-405 Wireless remote control (with CR2025 3V lithium-battery installed)
  • Microphone with integrated bracket (and attached 10' cable terminated by a right-angle 3.5mm connector)
  • Face pouch
  • USB connector mounting adapter
  • 2 Wire ties
  • Two 1/2" Self-tapping screws
  • Two 2mm x 6mm mounting screws
  • 4 Panhead ISO-mount screws (M5 x 8mm)
  • 4 Flathead ISO-mount screws (M5 x 8mm)
  • 2.5mm x 10mm machine screw
  • Face-fixing screw
  • 2 Removal tools
  • Quick Start Guide (Eng/Fre/Spa)
  • Warranty Card
    General features: Audio features: Expandability:
    • CD player with AM/FM tuner
    • built-in MOSFET amplifier (22 watts RMS/50 peak x 4 channels)
    • plays CDs, CD-Rs, and CD-RW discs, including discs loaded with MP3, WMA, and AAC files
    • built-in Bluetooth for hands-free calling
    • built-in HD Radio tuner with iTunes Tagging
    • PANDORA® Internet radio connectivity
    • fold-down, detachable face with 5-line LCD display
    • variable-color illumination
    • remote control
    • Sound Excellence DSP (5-band equalizer, iPod EQ, Highway Sound, time alignment, Digital E's crossover)
    • high-pass filters (speaker and preamp outputs), low-pass filter (sub preamp output)
    • receiver bypasses your iPod's digital-to-analog converter for superior sound quality
    • iPod direct control via USB input — no adapter necessary, but adding Kenwood's optional connection cable lets you leave your iPod cable at home
    • compatible with Kenwood's satellite radio and CD changer
    • inputs: rear USB and auxiliary inputs
    • outputs: 6-channel preamp outputs (4-volt front, rear, subwoofer)
Link do anuncio no Mercado Livre!
http://produto.mercadolivre.com.br/MLB-844382367-cd-player-receiver-kenwood-excelon-kdc-x995-bluetooth-usb-_JM
PODE SER RETIRADO NA ZONA SUL DE SP (Dependendo na Zona Oeste)
Editado por michel.balazs
Visitante
