- Encontro Som de Qualidade em São Paulo/SP domingo  EVENTO CANCELADO era 24/10 *****
Sign in to follow this
dfcarrilho
Pode fechar moderação.... Obrigado pelo espaço
mande contato no email marcelo.r29@hotmail.com
AMPLIFICADOR R300-4 USADO EM PERFEITAS CONDIÇÕES...1 ANO E MEIO DE USO...SEM DETALHES, USADO APENAS PARA TOCAR UM KIT 2 VIAS.
OTIMO AMPLIFICADOR PARA UM SET DE ENTRADA, CLASSE AB
IMPORTAÇÃO OFICIAL QUANDO A N.A.R REPRESENTAVA A MARCA NO BRASIL..TENHO NF E TUDO...CAIXA MANUAL FUSIVEIS ACESSORIOS E TUDO O QUE ACOMPANHA O PRODUTO.
VALOR: RS 300.00 DEPOIS VOU COLOCAR FOTOS DECENTES DELE, ESSA É A UNICA Q TENHO DISPONIVEL AGORA.
ESTÉTICA 9/10
FUNCIONAMENTO 10/10
CEA-2006 Compliant: CEA-2006_icon.gif
Number of Channels: 4
Rated Power
(RMS Continuous Power): 50 Watts x 4 @ 4-Ohm
75 Watts x 4 @ 2-Ohm
150 Watts x 2 @ 4-Ohm Bridged
Total Power
(Sum of Rated Power): 300 Watts RMS
Dynamic Power
(PVC/PowerCube®): Front Channels:
62 Watts x 2 @ 4-Ohms 0° Res
98 Watts x 2 @ 2-Ohms 0° Res
Front Channels:
61 Watts x 2 @ 4-Ohms 0° Res
89 Watts x 2 @ 2-Ohms 0° Res
Bridgeable: Yes
Frequency Response: 20Hz to 20kHz +/-1dB
Efficiency (average): 60% @ 4-Ohm
50% @ 2-Ohm
Crossover Controls: Front Channels
High-Pass (HP): 80Hz @ 12dB/octave Butterworth
Low-Pass (LP): 50Hz-250Hz @ 12dB/octave Butterworth
Rear Channels
Tone Controls: Front Channels
Punch Bass: 0dB/+6dB/+12dB @ 45Hz
Rear Channels
Function works when crossover in (LP) position
Signal Input: Low Level: 2 RCA pair
Signal Output: n/a
Power Input Connector: Screw terminal barrier strip
Power Wire Gauge: 4 AWG
Speaker Output Connector: Screw terminal barrier strip
Edited by dfcarrilho
Share this post
Link to post
Share on other sites
ESTÉTICA 9/10
FUNCIONAMENTO 10/10
Rated Power
Total Power
Dynamic Power
Front Channels:
Bridgeable: Yes
50% @ 2-Ohm
Rear Channels
Rear Channels
Signal Output: n/a
Share this post
Link to post
esse já foi... Vendi a algum tempo... Mas obrigado pela atenção
Share this post
Link to post
